Cam timing - distributor fitment
Sydney
Wondering if someone could help identify an issue I'm having with my 1992 3FE.
I purchased another FJ80 a few months ago. Whenever I get a "new" second-had car I like to go over it, change all fluids, check ignition, timing, vacuum hoses ... etc. Get a good feel for the truck and any problems it may have. I'm sure we've all done this.
Checked the timing. When I tried to advance the timing, I couldn't - the distributor wouldn't turn any further. I decided to take the distributor out to see what was going on.
Someone had ground the adjustment tab completely off the distributor. Where the retaining 12mm bolt normally goes.
Decided to get a new distributor, the previous had a bearing on the way out. There is absolutely no way I can make the new distributor fit and get correct timing. The only way would be to grind off the adjustment tab like the old one.
I was getting to the point I thought the cam gear might be out by one tooth. The engine has low idle vacuum, and seemed to have less torque down low, but felt like a turbo over 3000 rpm. I pulled it down, took off the front timing cover. The cam gear marks do align. So now I'm not sure what it is??
Is it possible that the distributor gear on the camshaft is out? What else could this be? Should I just grind the new distributor to fit? Or should I continue to hunt down the problem?
Can you post up a photo (or a link to a photo) of the modified distributor?
This is the the distributor:
cbS5ErW
Can you post up a photo of the head where the distributor is normally located?
Both photos below have the flywheel at TDC (double bb mark on flywheel).
This is my attempt at installing the new distributor. I noticed the gear has 13 teeth. So I added the 13 point star to the image. It looks like if I can somehow get the gear to mate up on the next tooth it should be correct. The bugger just doesn't want to do that.
This is how the old distributor is installed. Note the adjustment tab is ground off, and it's rotated much further anti-clockwise than it should be.
OK. Got the new distributor in after many failed attempts.
One of the previous owners must have given up fitting the distributor and decided to grind down distributor so it would turn the additional ~27 degrees.
Engine running?
Not yet. But I'm confident it will run. With the bolt in center of the tab, the rotor position is very close (relative to cap holes) to where it was with the old distributor.
I still need to put it all back together. I ended up replacing the front seal, a few gaskets, all the radiator hoses ... Just need to get a new A/C belt, and put the radiator back in.
When it's all back together I'll put the timing light on it, with jumper wire in OBD port, according to FSM.
