Hey fellow mudders!! I am moving on to the final stage of my build and starting to dial in some electrical accessories, lights, etc.
I have very little wiring experience. I have the basic assortment of crimpers, heat shrink, small rolls of repair wire, connectors, etc...
In respect to wire though: Do you think a 50-100' roll of 14 gauge and 10 gauge wire in both Red & Black should suffice to get me started on the basics? I am going to make sure I buy quality pure copper wire and not the CCA junk. THIS IS ASSUMING THAT WHAT I WANT TO WIRE UP WILL BE WITHIN THE TOLERANCE OF THE AMP LOAD AND LENGTH OF RUN.
My thought is that I can add wire colors over time as needed, but for now I am mostly just hooking things up that have hots and grounds. I am planning to use a secondary fuse block and I was just going to make sure that each wire that was hooked up was labeled properly so I can stay organized.
I was going to buy some stuff from WiringDepot.com and just between the 2 gauges and two colors for each gauge and a few other odds and ends, I have about $175 in my cart. Don't want to go too much more overboard.
