All right, I am ready to test out the new 4-wheel disk system, but before I coat my garage floor in brake fluid (drohweder) or shell out for a proportioning valve, I wanted to pose a question and have my “logic” reviewed.
I have a ’75 master so it has a dedicated reservoir for each brake circuit. I am/will be running ’79 disks up front and ’85 Eldarado’s in the rear.
Observations:
To date, I have not removed either of my residual valves from the master. With the ’79 disks up front and ’75 drums in the rear (leaking badly thus the upgrade) the truck stops well, no locking up, and the only side effect is that the reservoir for the front brake circuit overflows very slightly…
Hearsay:
I have read/heard from a number of people who have done the 4-wheel disk conversion and the consensus has been that about 40% of them did not need the proportioning valve, and the other 50% desperately needed it(10% not reporting) to make the truck stop correctly. Some with the proportioning valve say that they leave it “wide open” thus not serving any purpose.
Hunch:
I am thinking that the large disparity between those who needed it and those who did not could possibly stem from those who overlooked the removal of the residual valves in the master.
Theory:
Based on what a residual valve does, and the current behavior of my brake setup, it should be possible to eliminate the need for a proportioning valve by simply removing the residual valve from the front circuit and leaving it in place for the rear circuit. If the resistance created by the residual valve were great enough, the only drawback would be reservoir overflow on the rear circuit.
Variables:
NO...I have not compaired types of master...I know there are a lot of different ones being used.
Observations:
Hearsay:
Hunch:
Theory:
Variables:
