Cage Cost?
2badfjs said:
:eek: where you gettin you tube from zak?
i priced DOM last week 1.25-1.5" .0120 wall 24 foot stick at the most was $96.
most places wanted a minimum of $125. and that was a 20' stick
We got our tubing from another member of Rising Sun. 60' of 2" .120 wall DOM was $205. Bustanutley's tube was just over $40/each for 20' HREW and mine was just under $70/each for 20' DOM.
I have 40' here as well HawkDriver, so for a full family cage I have 100' of 2" and a bunch of 1.5 " and 1" for handles and crossbraces and details.
I am charging the camera battery right now so we can start photographing the whole process. :bounce:
Oh,
You are probably going to want to purchase 200'......
Learning curve... ;)
:beer:
and as far as a stock Land Cruiser rear hoop goes, I would not charge anyone for that, knowing that they would install it into thier truck, expecting it to save their neck....I would not want that in the back of my mind...
I bet it would not even smelt down good enough for gum wrappers... :rolleyes:
-Steve
now thats the hook up!!!!
My reccomendation, run HREW. lots cheaper and works fime for a cage that will not end up seeing multiple rolls.
Sweet! Just what I wanted to know guys, thanks.
I'll plan on around 150', I learn fast ;). Nah, jk. I'll get more when I screw up. Oh the fun that will be had :D . I'll be calling for local prices here soon, and my buddy mentioned some connections I'll check into.
:beer:
HREW will dent easier and once it's dented will be much weaker. So if you plan on smashing it, go with DOM.
You could always do the simple route and buy the family cage kit from Metal Tech 4x4. It's already pre bent with the unique profile A pillars that wrap around the dash and the B & C pillars are hoops meant to fit any soft top or hard top Land Cruiser. The A pillars are made out of d.o.m. and the rest is HREW. Though we just bent up some d.o.m. B and C pillars that are sitting in the shop right now. Just another route if you don't want to scrap all that tubing figuring out designs.
Metal Tech Family Cage
bustanutley said:
Last week I bought 80 ft of 2" .120 wall HREW for $165. That is wholesale. Bent B-pillar last night :). I already had my a-pillars from metal-tech which are DOM. I'm hoping I have some tube left over for a nose guard or some fenders; I’ll prolly have to pick up some more though.
wow, 80 ft @ $165 ??? that really is a good price. does anybody know of a metal wholesale place like this in the ATL area? The place close to my house wanted about $100 for some 18 ft of 1x3 square tube for sliders... haven't bought them; I though I can have them made for a little more than that and would have to worry work...
Hmmm, what makes DOM so much superior to HREW???
:D
Check out http://www.metalsdepot.com
thier prices are Ok if you leave near them the shipping are Ok they don't overcharge you can get an idea on the prices of steel
:D
HREW has a weld seam. When force is applied to the the tube it will concentrate on the seam.
DOM has no weld seam, because of the process, so force is eveny distributed.
You sure about that???
Dom DOES have a welded seam. In fact, it starts out as HREW before it is Drawn over the mandrel.
Yes, but because it is drawn over the mandrel you eliminate the seam (hence my " because of the process" statement). DOM has an even wall thickness.
Mark of MetalTech told me somewhere that there are different qualities of tubing or of the steel used in making tubing in the market. Some apparently from offshore sources that is of such low quality that he doesn't use it.
Might want to research that possibility.
ckindel said:
Noob alert (me).
A "family cage"? I assume this means a cage that allows for a bench seat in the back vs. the jump seats?
Sorta' but not exactly. It means a cage that surrounds and protects the entire interior area by having a third loop or pillar system and full headroom all the way to the back of the truck. Doesn't really matter what kind of seating there might be in the back.
