Cab Wiring Help..
Alright the last owner of my 04 tacoma (trd, don't know if that matters) just ruined random wiring in the cab of my truck.. so I'm trying to see if someone already knows which wire goes where.
Giant Ground under the drivers seat, under the carpet.. where is it supposed to go? It's just hooked to the body.
Second color is stripe
1-blue/red with white/black coming out next to the airbag control thingy with a yellow crimpy tube on each one
2-red/black with white/black(X2) Same Area, with a 90 degree kinda plug thing
3-green/black with white/black coming out of the floor under the driver seat, no plug (anymore at least) just cut wires
4-And a plug with them with a black like a black stopper in it.
alright I think that's it
Shame on the person that did that. Prolly some doofus that works at BestBuy doing hack stereo installs.
The ""giant ground" is definitely not factory, they must have had a big amp under that seat. Take it out, leave the screw in so you don't get water in the cab.
I think the green/black & white/black pair goes to the seat belt. Toyota uses white with black stripe as a standard for ground.
Thank You KLF, you're the only person through three forums that's given any kind of answer.. the wires on the seat are black and black.. does it matter which way the wires go..?
