C-clips on Birfield
San Antonio TX
Where is/are the clips located on the axle that holds the birfield in place? I see one at the backside which is where I believe you can tack it in place for the Marlin Tack method but, Is there another one on the inside of the birf? I am almost at the point of no return on the disc conversion and wanna be sure I dont miss something that needs to be replaced...
Thanks
Thanks Ranger, I've seen that post but, I wanna know where the clips are actually located. Are there one or two? My guess is there is one located inside the birfield? locking it onto the axle which is why you have to break it to get it off, or, it's the one behind the birf and it is held in place by the "teeth"? on the birf itself......
2, one onside the bell and the one outside the bell.
both on the inner axle
There ya go. So, I suspect the one on the inside is the one that snaps when you do the ole pipe removal method?
I use a zip tie aka Wire tie for compressing the clip.
Works like a charm.
but my inners are martacked as well...
