BVSV
Madison, WI
I was replacing vacuum hoses and broke off the nozzles on one of the BVSV’s (see second picture). I ordered a new one and tried replacing it tonight but I couldn’t screw the new one in all the way. My frustration got the best of me and I really tore up the metal on the BVSV “nut” (see first picture). I’m going to try to even out the sides with a die grinder, but I’m trying to figure out why I couldn’t screw it in all the way. I’m wondering if it’s the green plastic that is around the threads on the new BVSV. I thought that was a self sealing gasket that I had never seen before, but now I’m wondering if I need to remove it in order to screw it in? Any help is appreciated!
View attachment 3315751View attachment 3315753
what EXACT tool or tools were u using to install this NEW BVSV ?
i see that and this as your potential install issues here
- post photos please of EACH end EVERY tool u used today please ,
- i know when i do this exact task here , i DO have to change up tools due to clearance issues to other parts etc .....
i will await your reply , so report back
thanks
matt
664dc77d-46b5-4e64-9daa-8a25eeb51f10-jpeg.3315751
It’s like tapered pipe thread, with sealant already on the threads. You don’t need to screw it all the way in. Just screw it in until snug. Get a new one and start over.
I have so much trouble with these parts that don't screw in all the way. I need to get used to them. Thanks for the info.
You found out the hard way those BVSV housing are made of VERY SOFT BRASS for a reason - They go into an even softer, thin-wall aluminum housing. Just get them tight enough and nipples angled correctly and the green sealant does the rest.
I forget the size, but I bought a cheap Harbor Freight DEEP six-point-socket and cut a slot in it to clear the nipples, so it's like and oxygen-sensor socket, and works great.
You don't want the BVSV protruding too far into the Thermostat housing anyway.
