Buzzing after cold start
Salt Lake City, Utah
My 1997 LX450 has been making a short buzzing noise right after starting cold (zero to fifteen degrees) when cold. It buzzes for a few seconds, then everything is normal. It has also coincided with an intermittent starting problem where nothing happens when the key is turned, possibly suggesting starter contacts, but I replaced the starter contacts about six months ago, so I don't think that is the problem. I will check the battery connections tonight and ground connections for any corrosion. Any other suggestions? I hate to pull the starter out, but may do it for peace of mind.
I found some old threads with similar symptoms (buzzing after starting when cold) and it was suggested that it had something to do with the power steering fluid being cold. Any other thoughts?
Thanks.
not sure if is the same thing, but I do get a high pitched whine on very cold days. I believe mine is the fan clutch. I did a search and others had simailar nioses. It goes away after a few seconds. The clutch is still good, just takes a second for the oil to cover the bearings.
Could be the power steering as well, I have seen some posts on synth fluid, but so far no real problems .
Boz
Likely the "cold start rattle" The timing chain tensioner is oil pressure driven. The noise your hearing is probably the timing chain slapping the against its cover before the tensioner is properly pressurized. Some have had luck simply changing to a different , smaller OEM oil filter, others have found no solution what so ever. If it is the cold start rattle there is no danger, just mildly annoying.
As far as the intermittent starting, if its NOT the contacts, this thread may help. https://forum.ih8mud.com/showthread.php?t=125974
Good luck and keep us posted.
Timing chain tensioner is a plunger that pushes against the timing chain slipper.
I am thinking starter only.
Mileage JZ???
If you are in the normal mileage range of a 97 (100-200) and the starter has not been serviced (contacts and plunger replaced) I would say this is your problem. The biggest hints are sub-freezing temp issues, and starting issues under (normal) temps.
Thanks.
I've heard this buzz before although it's been quite awhile. It's not the same as the start up rattle as mentioned above. It's literally a buzz sound, not a rattle. I can't say that I've heard it since the fan clutch was replaced but I never considered that it was the cause. Always figured it was cold power steering fluid. I wouldn't let it worry you.
Find out what it is before you decide to ignore it..
Power Streering Pump!
Cold weather rookies....:rolleyes::rolleyes::rolleyes:
Cheers,
Sean
I don't know if it is the same noise, but if I park my 80 with the wheels anywhere but straight, I get the buzz when its very cold outside. If I leave them straight, it starts without the buzz. I am under the impression that its a cold PS fluid thing. Once it starts, the steering is fine, so I wasn't concerned
-TT
Thanks for the replies and the links to threads (MoJ). BTW, it has around 80,000 miles. I went ahead and checked all the battery connections and ground connections that I could find and they seem to be fine. I am still getting the buzzing sound intermittently and it is definitely not a rattle. I noticed that if I turned the ignition to the point just prior to ignition I will get the buzz, does that help? Unless I hear otherwise, I will go with the power steering pump.
I am guessing that the no starting issue is an unrelated starter problem. I may have to pull it and check how well my previous replacement of the starter contacts is holding up.
Is your heater fan on? If so it is the fan motor it will buzz if left on one of the higher settings. Mine does but it usally after it drops below 5. It is -25 out right now just to fill you guys in who think your cold:cheers: .
Interesting. This thread has me wondering if I wrote off power stearing issues as the"cold start rattle". I just started mine to let it warm (about 17 degrees out) and got the buzzing noise. about 2 seconds at most, then nothing. I wonder if changing to fresh fluid would help?
a "zzzzzzzzzz" sound during a very cold ambient start is the power steering pump......normal.
I heard this sound as well for the first time yesterday when I was cold starting in Leavenworth at 0 degrees F. It is definitely a buzz sound, but only lasts for a second or two. Good to know this is normal.
My '94 has the same issue. I suspect Power steering fluid. Mine was low and made more noise until I topped it off. I just take it as the cruiser complaining about the cold. On a related note, my heater fan motor was making noise as well this morning. Temps were -2 F. Noise went away after about a minute. So now I have a rough temperature gage. Noisy startup = cold. Noisy fan motor = really cold.
Wonder what Alaska cold would be... Then again, I hope I never find out.
