I have the opportunity to buy some used BFG KM2's mounted on Tundra Rims. They are very lightly used but I have had bad luck with used tires in the past on smaller cars so I have not wanted to risk it with the bigger tires. I have had two different instances of a bulging tire tread. I was told it was due to the tire being put on backwards from its original direction. For that reason, I do not rotate my tires side to side anymore either. Just front to back. If I buy used tires, I assume I get a 50/50 chance of installing them correctly. Any reason that is true or not?
