Burnt Fuse?
The battery - cable runs to the frame. The starter has a separate ground strap that goes to the frame. If you run the battery cable directly to the starter, you still need the connection to the frame. None of this would have anything to do with the fuse blowing.
Is the fuse burnt or blown, sometimes corrosion will build up around the fuse heads and time will allow the fuse holder to spread slightly, the resistance of the corrosion will heat up during a high current event and can cause minor arching or the voltage drop accross the corrosion will cause heating up around the fuse head causing it to look burned, just a thought, Cheers, Larry
