burning wires
College Station, Texas
I've got a '77 FJ and keep having trouble melting one set of wires. The wires run along the passenger fender and branch off to the right headlight, a body ground under the coil, and one lug on the back of the alternator. It only happens when the battery is low and the starter draws more amps. Sometimes the wire just get really hot really quick but if you crank too long it will smoke it. I don't remember what color the wires were originally but they are connected to the white with black stripe wires on the right fender. Any help would be appreciated. Thanks, Matt. P.S. The amp meter is showing a discharge now also.
My guess:
You've got a bad main ground between the engine, the frame and the negative terminal of the battery.
The current from the starter is being forced through the small guage wire and the wire is "smokin'".
You need to go through all your main (heavy duty) grounds.
People recommend (and I concur) that the engine ground to both the frame and Negative Battery Terminal. The Negative battery terminal should also ground to both the frame and the engine.
You need big straps or cables.
I've got a "dual post" Orbital. It gives you two locations to set up your grounds, the top post, and the side post.
Good Luck -
Rocky
What Rocky said. I run a ground strap from engine to frame and from frame to tub....using these....
A dedicated cable from the negative battery post to the engine block works best......
I have a dual post battery as well. Problem is, I have my 8274 attached to the two extra posts. I'll run the negative battery cable directly to the block and then use cable straps to go from the engine to the frame and from the frame to the tub. Is that correct? What would be the best place to attach to the tub? Thanks, Matt
Actually the alternator quit working altogether. I have a reman to put on tomorrow. I didn't check the voltage while the old alt was still working. I didn't assume a high voltage problem.
