burning oil
East Vancouver, BC
my 1977 fj40 2f is burning oil like crazy. nothing's smoking, nothing's leaking, my crankcase just seems to go dry before i can do an oil change. the only way i noticed is when the cruiser sounded louder and gnarlier than usual, and i saw the oil guage doing some ups and downs. so i went and grabbed some quaker state high mileage and 2 cans of bardahl 2, now she's running smooth. anybody else have this problem? any product recommendations as far as oil or treatment goes?
:confused:
Does not add up....
Pull the plugs, what do they look like?
Hmmmm...The Case of the Disappearing Oil...
We need facts, Dammit!
Pay closer attention to your dipstick,man! Tell us how much oil how often. A quart a week? 2 quarts a tankfull? Waiting for oil pressure gauge fluctuations is not good.
The thing is, you are burning oil. Nothing's smoking? Wanna bet?
Buy a case of oil, keep it in the rig. Buy a compression tester, search "wet test" and "dry test". Get back to us with numbers.
well it's not smokin, i took a rag and hung behind the exhaust pipe, looks like i'm spitting very small drops of oil. the plugs aren't coated or nothin, i just replaced them 2 weeks ago though, same time i did an oil change. i gotta full crankcase right now, i'll keep an eye on it, it's my daily driver, lots of stop and goes through short distances. and it's not exactly like i'm 'waiting' for the oil gauge to fluctuate before i do anything about it. i'll also have to pick up a compression tester to get some numbers for ya.
How often do you change the oil? If it went down slowly over time, then you just need to pay closer attention to the oil level. And NEVER tend to your oil based solely on the gauge--you ought to be checking it regularly regardless of what the gauge says.
All engines burn oil. Engines can burn a lot of oil without visible smoke coming out the back. You'll smell it long before you see it, and it'll be burning oil long before you smell it.
Oil spritzing out the tailpipe is not so good.
metalonmetal said:
is this a problem with the rings? i definately can't see the smoke, neither do i really smell anything.
You need to tell us this....your compression numbers will give you a fairly good idea as to what is going on....
Mine used to burn a TOn of oil under heavy throttle.
Other than that it was fine.....
So I never saw any smoke and the plugs stayed fairly clean...
lets just hope there was oil in it in the first place.......... perhapse it was dry and now finally is gettin some oil.
