Bump It Offroad (BIO) sliders
South Jordan, UT
In conjunction with a rear bumper and tire carrier, I also had Bump It Offroad build me a set of basic sliders. These are the standard BIO 100-series slider, but without the bump-out. I took delivery of these in bare metal, and had them powder coated locally to match my Slee front bumper.
The mounted up easily, with the exception of a minor clearance issue on the center mounting arm on each slider:
There was a 1/16" to 1/8" gap between the mounting surface and the frame rail. I shimmed this gap with some metal strap I cut down to make the fit perfect. I don't know if this is a common occurrence with 100-series sliders, but it's an easy fix.
Also note that I completely removed my AHC system. An AHC equipped LX mounts sliders differently (with two mounts per slider as opposed to three). These were built for non-AHC Cruisers.
The sliders are well made, cleanly designed, and sturdy.
My only complaint is due to the nature of typical tube sliders and the LX body cladding:
The front tube runs too close to the lower body cladding, and contacts it if you snug the sliders up high enough. I anticipated this and had Mike at BIO move the junction of the tube back slightly on the main rail, but it's still too close in my opinion. It's more the fault of the LX body than the slider--the body cladding sticks way out there, and needs something to protect it. I've opted to run the slider right up to the cladding. We'll see how that works out...
Quick Threadjack - What kind of roof rack do you have?
Looks awesome, nice job. You just need some matching tint on the front windows and you're ready to go.
I like it when the idiot next to you throws their door open and they dent their door on my step slider ;)
I have a feeling a couple of careless people at work have learned the hard way to be more careful opening their doors when they park next to me for that same reason ;) Doesn't bother me at all to get a little colored paint on the slider but I doubt the mark they get on their door is less noticeable!
I went White Knuckle on the sliders and couldn't be happier. Freaking love my BIOR rear bumper though.
I like the idea of no bump out because it gives a cleaner look to the vehicle. Do you know what the purpose of the bumpout is in the first place?
If you're on a trail and slide sideways into a tree, the only way you can really go is forward. The bump out prevents body damage by pushing back against the tree and putting space between the tree and the body of your truck.
