build thread of (ole red)
mounting the engine and trans back together installed the engine mounts going to try stabbing for the first time this week ended up having to order some hookers lol for my exhaust
The only acceptable time you can hang out with two hookers and a tranny :D
When are you going to have this thing ready to go to the Mall? Get off the Couch, Get your hands out of that Cheetos bag, GSMTR is bearing down on you!
I have been under the weather for the last couple weeks haven't done much on the 80 I orderd some parts my snorkel came in and I'm ordering a triple stick cable shifter for the 203 and split case and my twin ARB compressor come in if anybody has one mounted in an 80 I would like to know where you mounted it.
also sent my headers out getting ceramic coated should be back this Wednesdaye
I'm moving my front brake lines from the master cylinder back towards the firewall and going from the master cylinder with stainless steel braided lines
Look at those headers shining like a diamond in goats ass.
Dang where did you get the shifter from?
JB custom fabrication, it. Is for a 203-205 set up, but I'm going to make it work on my setup.
Santa's little helper has been busy. Hope to see it at GSMTR.....
We expect to see a motor in there by the end of the weekend.
got the engine w- new firebird oil pan - trans and both t-cases in, made t-case mount and installed rear cross-member.
Installed SS braided brake lines on rear axle, installed rear drive shaft [slip yoke] looks great. In the process of pulling the gas tank to clean and install Turbo Supra fuel pump.
