BSLCA BS... ie.. local chat..
I think I know how the PO dented my fender.
It pretty much matchs my dents I bet.
They musta repainted all of my truck.. :D
Thanks
Cody
Thanks
Cody
If you're serious, they did the firewall and underside of the hood etc??? Also there is something in the VIN for the color is there not on the 62?
Ouch on the pic tho.. that day musta sucked.
me
Nah, I'm not serious. I was browsing the Net searching for cruisers and saw that. And had a little laugh.
Plus I don't dents "like that" on the doors.. :D
Thanks
Cody
I would also think you would see some sign of it on the axle, spring plate, or knuckle areas.
Yesterday i had a bad day when i was going to Sulpher, LA., i was going up the gun bridge when my drive axle broke at the TOP! I was thinking it was the clutch. The big nut in the middle of the axle back off and came out of the spline, now my spline is all fk up, that the one in carrier bearing on the axle. if someone has one in a shop doing nothing give me a ring.
I look tomorrow.
Are you talking about the pinion flange nut on the third member?
If so I have a flange and nut from a elocker on my work table that might work.
Also PAP had a 2wd Tacoma, and the nut is usually a 30mm socket size/
Have my green light on going back to LAF., thanks John i will today.
Now im fk mad sitting on side of 10 mile mark 53.
yep my brother, drop my axle off at USA Driveline. No more carrier bearing!!!
K cause I was passing thru and maybe could have given you a lift if you were still there
working my truck tonight, taking the front drive axle off. USA Driveline my axle be done tomorrow sometime. Hope i can get the front punkin off without taking off the lift.
anyone know if there is a toyota with a 22r in pull a part right now? Needing to rob some bolts and screws off of one.
Happy Birthdays guys :bounce: Hope ya'll enjoy the day and relax :clap:
