Broken wiper seal bolt question
Iowa
I was putting the front axle back together and was tightening down the last wiper seal bolt when the head snapped off. Bolt was below the surface so vice grips were a no go. I tried an easy out but it won't grab on. Is my only option to drill and tap and if so, what am I going to need to get it done?
Any help is appreciated!!!
I did the same, ran it without for a bit. If I recall, these only need to be 14 INCH pounds. When I finally got around to drilling it, it came out easily with no need to tap it.
Try a left handed drill bit that's smaller than the hole, start small and start going slightly bigger until you can extract it.
And use your ginger fingers.
Believe it or not, the $10 Harbor Freight bolt extractor set will prob do this job for you.
Use the included smallest right hand drill bit...then the also included smallest left handed bit.
John
