Broken ring gear - questions!
Jefferson State
Now I've done it...My 96 FZJ80 has been doing time as my wife's kid hauler/grocery-mobile since we bought it used coupla years ago. We planned to build an expedition/wheeling rig out of it in a year or so, but...couldn't wait 'til then to wheel it. After playing around on some of the trails labeled "Most Difficult" near Big Bear Lake (nothing as gnarly as I've seen posted here!), then taking a 12-mile fireroad trip outta the forest, the right front wheel kinda "caught" and froze up as I was pulling away from a stop. It was pitch black, and all I could see with the flashlight and the wheels off was what appeared to be a leak at the back of the front diff (dripping everywhere). I had to move the truck to get the kids, carseats, and gear out, so I was able to determine that she rolls fine in reverse, but will catch & freeze after a few feet of rolling forward. With help from a friend who knows a lot more about diffs than I, "we" determined that I have likely broken the ring gear. So... my plan is to replace ring gear and do a full axle rebuild. At 165K, she's due anyway. Romer's rebuild FAQ is a great resource and I'm confident that my 1-banana ass (with help from afore mentioned friend) can tackle this, but before I commence:1. What other diff carnage should I anticipate (i.e. anything besides the ring gear likely to be damaged)?2. If I'm planning a mild lift, armor, etc. and 35's in the next year or so, should I replace the stock 4.10s with 4.56s while I'm going through the trouble (I might as well service the rear axle while I'm at it)?Any other sage-like advice would be appreciated as well!Thanks,Jason
Gear set-up is something you might consider letting a pro do, although pulling the diff and servicing the axles would be a great way to up your banana rating. :D There's no telling what might be wrong with the axle until you open it up- might even be that the ring is fine and you toasted a birf. If you do end up replacing the ring, it would be a great time to regear if you feel you'll need it in the future. Either way, you might as well service the rear axle if it's due.
-Spike
Bet you broke a pinyon, mine locked up just like that too............not at a stop though...
IMHO a R&P job isn't as hard as your always led to believe. I've done them before on dana 44 's, but not on any toyota axles as of yet. I would think a toyota R&P job would be easier than most because you get to take out the whole 3rd member and do the R&P fitment on a work bench, not underneath your car. As long as you have the right tools and are patient enough to set it up at least 3 or 4 times you'll be fine.
After a long haitus, I managed to dig my rig out of 4' of snow to complete the removal of the 3rd member and begin diagnostics. Autopsy revealed a single tooth decided to part ways with the ring gear and lodged itself just underneath the pinion. I'm not schooled metalurgy, but it kinda looks like low-temp stress fractures seen in forged aluminum - go figure.
Despite the carnage, everything else appears in good shape. Fortunately, a neighbor has a stock 4.10 front sitting in his garage (another unfinished FJ40 project piece). This will get me back on the road sooner, as I'm short on both the time and $$$ neede to regear.
I am a bit puzzled as to why it broke. Everything else in the diff, axles, & birfs looks pristine, given its mileage and work history. Any thoughts?
Bear - Getting home was the easy part. I lost mobility about 40 yards from the end of the fire road approaching a state highway. That, and a buddy from a local 4x club drives a wrecker. :D
Here's to being lucky! :cheers:
And the Cruiser Carma Continues.....:cheers:
You could've driven home by removing the outer drive plates, front DS and pushing the CDL switch. In case, you don't have a CDL switch installed in one of the blanks and plugged into the CDL harness that's already present, the hazard light switch can be substituted in a pinch!
... In case, you don't have a CDL switch installed in one of the blanks and plugged into the CDL harness that's already present, the hazard light switch can be substituted in a pinch!
Or shift low to lock the CDL, pull the locker fuse, shift high and drive.
All gear pieces are made from steel not aluminum but as you modestly stated you are not a schooled metalurgy.
Any how if your friend front end is from a FJ-40 it will not fit yours since front FJ-80's carrier is smaller and is a reverse cut unlike the FJ-40's which use the same carrier as in the rear end.
Robmir - I feel I need to defend my honor here. Despite my ignorance, I DO know gears are steel. That's why I thought the characteristics of the crack were curious (to my unschooled eye, anyway!) Just interesting, that's all.
And my friend's front end (that doesn't sound right...) is from an 80 (a '96, in fact). He had visions of modifying an 80 drive train to fit on on a strecthed 40 (complete w/coil springs). Alas, it was just another case of "eyes bigger than your stomach", so to speak. Would have been cool, though. And I reap the rewards of getting free parts (if you don't count the beer & cigars).
Alia - Cruiser Karma has been good to me when it counts! and I will no longer procrastinate on the installation of a CDL switch (kind of a no-brainer, really!)
Tools - thanks for the the trail tip! I think I've read that here before, but was too stoopid to commit it to memory.
Thanks again for the help. We just got another metric assload of snow, so it will be a while before I complete the repairs (at least the gear is an and the 3rd member ready to install).
Point taked LOL:o
Agree with you, the crack characteristic also make me curious cause your cruiser is AWD so the front end was allways rotating unlike mine which is part time and have unlocking hubs. Talking about manufacture fault after more than 100K is unfair. Well looks like a cold case as the cops say !!!!
Your friend vision doesn't look so crazy cause the latest FJ-70 series came with front coils and drived the FJ-40 vs. the FJ-70 you notice a better handling ( 70 series still have rear springs)
