broken lug bolt
hey everyone,
As I pulled out to go get my new shoes installed (33x1250x15 mud terrains) I heard a loud sound like something broke loose. It happened as I was slowly driving off the curb. I got out and checked the suspension and everything was good. After I got back I found one of my lug nuts on the ground still attached to half of a lug bolt front the front/passenger side wheel.
My question is this;
what size lug bolt to replace?
More importantly, should I consider replacing all of them? Something as simple as driving shouldn't brake a lug bolt, so I worry that mine have become brittle? Is this possible?
BTW, the cruiser looks great with new shoes :cool:
nutsnbolts
Listed above is a great Mud source for bolt info. When a stud snaps like that it can't be good. The torque for the wheel studs is (70-80)ftlbs, second source that info.. I have a sneaky feelin your studs have been overtightened. Suggest replacing all of them on that wheel. And so what you are saying is that you went down to a tire store and had them put new tires on. You meen to say then that the guys down at the tire store never told you of the broken stud? I suggest never returning to that tire vendor again. I use Les Schwab tires for my tire service whenever possible. They will tell you about any unsafe condition and offer to fix it for a small fee. IMO, choose your tire vendor carefully, if you don't see them using a torque wrench, never return. If they pull a stunt like what happened to you then that is a huge red flag. Just curious, who installed your new set of tires?
He said it broke off on his way to get the new tires.
Meh. It happens. It was probably overtightened. In my experience, it's easiest to just pound out the remainder and take it in to your local parts house and find a match. Knowing what size it is only helps if the parts store knows what size theirs are (which is not necessarily the case) :doh:
The reality is that millions of lugnuts get put on with torque-limited impact guns every day with no issues. If your tire shop is even reasonably prudent in using the proper torque extension, the effect on the lugs is minimal IMO. I still don't entirely trust that it's done right, but I wouldn't trust the tire jockeys to set a torque wrench either, so I always do it myself at home.
Shenaneguns! I declare shenaneguns! e rock, I never said the tire store caused the problem. They just ignored it. That is what is BAD.
wheel studs are M12 X 1.5, do not buy the grade 8.8, get grade 10.9 or better. Metric strength standards do not translate to SAE. Take a stud with you when you go to buy new ones. That way you can match lengths.
information derived from:
https://forum.ih8mud.com/40-55-series-tech/180924-need-slightly-longer-wheel-studs.html
Information was found by doing a search under 40/55 tech,, title "wheel studs" selected search title, not search thread. At first pc 440 it seems difficult, at least to me, to nav this site. Maybe there is a description somewhere on how to do a proper search. My only motive is to be able hand you a powerfull tool enabling you to better take advantage of this excelent resource. As e rock pointed out, a good click style torque wrench might be a good addition to your tool box if you do not already have one.
Richard
1. Lug nut with partial bolt broke off BEFORE I got the tires put on.
2. I had the tires put on at America's Tires
3. I did see them use a torque wrench so I do trust them to a point.
4. Yes, I am surprised they didnt mention that it was broken. I guess they were in a hurry as it was getting close to closing time (no excuse though).
5. I was the last one to tighten my wheels when I did my lift 2 months ago so I guess I must've over torqued :doh: using my lug wrench. Guess I dont know my own strength (armstrong steering :flipoff2:)
Thanks for all the info, I will stock up on some lug bolts.
