Broken front output shaft
sykesville,md
Broke the front output on my Orion today. The original Toyota front output. FJ40 1976, SM420, Orion 4.1, SBC, 38.5" TSLs, stock ring and pinion, BL 30 splines, locked f/r. Had the front wheel wedged between two boulders with all 4 tires spinning in first gear. My question: Is there any stronger output shafts out there, can it be treated or cryoed? I have three extra t-cases so I have a few more shafts. Does the front Orion HD housing fit a standard Orion? Thanks.
Hi All:
Yikes dude! Sorry to hear about the carnage!
I knew that the Orion required the use of the stock front output shaft housing, but did not realize it used the stock front output shaft as well!
Got any photos? :D Seriously, strictly for diagnostic purposes! ;)
Good luck on the re-build!
Alan
just curious do you think it just twisted off , are you running a CV shaft ? or regualar shaft? i twisted mine off last year ,similar setup minus the orion . i started looking at everything . and I was wondering if the ujoint might of binded up causing my shaft to snap off . non cv shaft. i have since clearanced my u joint .and all has been good so far.
