- Thread starter
- #41
After using my factory jack on concrete I figured this was a must have out on the trail. Just placed order
Thanks for the order
Hopefully you wont need it on the trail but it is nice if you do.
Ive ordered and received. I like it, it’s a great idea. But I want to use it on a bottle jack,
I think the pressure will do just fine, any suggestions?
Just ordered. Looking forward to never needing to use it on the side of some dark road in the rain.
I think I asked before, in another thread.... Does the factory jack lift the tires off the ground on the front (OME Lift, 32.5" tires)? Seems like I about maxed out my fairly tall floor jack at the diff support to lift the tires off the ground recently.
Not a problem, pictured is ~33" tires with no diff drop and the jack has more lift available
Is the skid normally covering right there?
Honestly I have no idea because mine went in the trash the first week of ownership.
Where do you place your factory jack now when lifting the front?
I haven't yet, I would probably aim for the lowest solid point on the front end! I might start taking the 100 series off the pavement soon and I want to have a good kit so that I can change a tire on the road if I need to. I plan on adding sliders to the LX soon, so I would be able to use hi-lift and adapter, but I won't have the hi-lift with me unless we are on a trip. I suppose if I have an issue with height with the factory jack in the front, I can make an accessory to extend height with some round tube and solid rod.
Just ordered along with some mis flap eliminators.![]()
