is this why my dam insurance i so dam highHntWhtTail said:Ok I will share with all the wisdom that was passed down to me by a stereo thief. Get a rectangular piece of flat flexible vinyl or plastic. 2" wide by 2-3 ft long thiner the better but must be stong enough to attach a 3 foot piece of cotton string like kite string. Attach the string to one end about 3/4" in from one end center. To use Hold string in one hand, and insert the end with string atached in to vehicle letting the string go with it hold on to string...go past button, and pull back on string should flex plastic thing get string behind button lower both string hand and other until you are around the button, holding tension on both pieces pull up on button....for the toyotas buttons you have to put two wraps and cinch the string tight, with a little practice you can get into your rig in less than a minute. I keep one under my tool box in my pickup(just looks like garbage so nobody messes with it) great way to meet chicks. Or save a stranded motorist for your good karma..If you are prone to locking your keys in hide it up on top of your spare tire, you can use a coat hanger in the same way with the string attached.
Jamie
is land cruiser still the mosyt desired theft vehicle nice trick anywayHntWhtTail said:I would tell you all a very simple tool that opens any vehicle with pop up buttons(yes even the ones toyota uses) I would be forced to kill you if I shared this information.
