About to order some UR adjustable arms to adjust pinion angle. I see some range from $250-450$ish. Besides thickness does each manufacturer's arm do the job with the same result?
With that said should I avoid M-A-F adjustable arms?
Yes, I have them and the poly bushings were shot in two trips... Then the heims started squeaking
