Braking system
Vancouver, B.C. Canada
From what you guys have tried what is the best booster/master combo. I read that an early 80 minitruck booster will work. In that case can i use a V6 master in that combo aswell. Let me know what you have found to be the best combo.
If you have a 78 cruiser, does that mean that you have a booster/dual master to begin with???
I switched to an 84 Toy Pickup one-ton booster/master combo- and I love it!- but that's because I had a 1969 single reservoir, no booster master cylinder that was crapping out on me. I went from pump-pump-pumping away, to a much safer braking. If your brakes work, then keep them. If you're turing big tires, then maybe add some more umph. But if it aint broke, don't fix it....
