Braking problem
Fallston, MD
I know, another braking problem thread. I did search for the last several hours, and my head is spinning.
Here is the deal, I am currently looking at a 1991 Cruiser that is having brake problems. I have not driven it yet, he is an older gentleman (original owner) and said that the front brakes are not working, but the back brakes are. He said he took it to a shop and they replaced the master cylinder with no luck. I have read a lot of threads about bleeding and the lapv, but I am not sure if either of these problems would cause the front brakes not to work, if indeed they are not working, or just working poorly.
This is all a pre-purchase jitters, because it seems from what I have read that the brakes can be real pain to get working correctly.
I am going to drive down and take the thing for a test ride on wednesday to see how it feels and have a look at the overall condition of the brakes.
Any input would be appreciated.
I'm not really familiar with the LC brakes yet, but non-ABS brakes are really pretty simple. If the LC is cheap enough, caliper rebuild kits are pretty cheap. Rebuilt calipers are not too expensive either. Find out why he thinks the brakes don't work & don't take it to the place that replaced the master cylinder, doesn't sound like they know too much. Just be careful on the test drive.
Sounds like calipers... Easy repair.:popcorn:
As mentioned the calipers could be the problem if seized.
Pads and/or rotors could also be he problem. If they got glazed the effectiveness goes waaay down.
Either way, I'd count on R&Ring the front. If you need to replace your front rotors, might as well do the whole front end job...
Naw. Go with OEM. Feed Cruiserdan's dogs. :cheers:
Don't know but since I had no so pleasant experiences with the OEM rotors on my two 80s, I went the non-OEM way and I haven't regretted yet, here's a picture of the product installed on my 80 at a fraction of the cost.:beer:
So I got some more information from the owners son in law. Apparently the guy had the hard rear brake lines replaced, and they could never get the pedal feel back. They replaced the master cylinder with a reman unit, and no difference. So I assume if I bleed the brakes really well, including the proportioning valve, then I might be back in business. :hhmm:
My main concern about drilled and slotted is them filling up with crud. And that's a serious concern around here. I killed a pair of front calipers from clay getting under the boots.
I've been very impressed with the OEM setups. Even with my truck, I managed to rapidly slow down on a very steep downgrade while towing a 3k lb boat (idiot in the other lane wasn't in his lane, nearly hit him).
The :princess: truck will quite literally throw you through the windshield. Hers I thought was just "okay" until I changed the rear calipers, rotors, and pads, now it'll stop on a dime.
I'd take either one for stopping over my pops 2003 F150, by a long shot.
Bet ya dollars to doughnuts that there is now air in the ABS actuator.
Take it to the stealership, have them bleed it and be sure they use their little tool to activate the ABS actuator while bleeding. You cannot get air out of it bleeding on your own.
IIRC several people have had it done, and it's been around $100.
Update
So I had the rig towed to a friends shop, and we tried bleeding the thing for 40 minutes, to no avail. When we got it up on the lift, we can see that the lines had been changed forward of the LSPV, but they used compression fittings, so that will have to be taken care of to pass inspection. We first started with gravity bleeding the brakes, then started the pumping operations starting in the back. My buddy was able to get a stream out of the PV, but little out of the rear wheels. We then moved to the front with a vacuum bleeder and started to get some out of the passenger front, but none from the drivers front. This was with the vehicle not running, we couldn't start it due to the missing cats (which are on the way). My concern is the compression fittings and some rusty hard lines up in the front, they don't appear to be leaking, but I wonder if this is a factor?
Also are the lines from a 1995 the same as a 1991? I know the 1995 most likely has abs, but I am thinking of starting fresh(er) with some 17,xxx mile lines.
I wouldn't hesitate to start the vehicle without cats. Matter of fact, I haven't hesitated several times. :hillbilly:
I would think that the hard brake lines would be very similar if not identical, but the rear is likely slightly different due to drum vs disk.
I would contact cdan and get new before putting on used lines. Braking is one of those things I just don't mess around with.
Not on a 91. No ABS.
Please stop with the used brake line nonsense. There are parts resources here on MUD that make it easy to get the correct parts for your vehicle that are an exact fit and function. John Hocker or Dan make it very cost effective and it ships to your door.
The brakes on a non-abs equipped 80 are pretty straight forward and contrary to popular opinion, they work pretty damn well if properly maintained. You're on the right path by bleeding the lines first. Obviously if you're not getting fluid from a caliper you've found at least one problem. Bleeding should be done from the longest leg first.
If it were my truck I would pull off all non-OEM parts and start again from the beginning. But that's how I roll.
If the truck was still supported by the lift while you were trying to bleed the rear brakes, the LSPV would have been biasing most of the brake power to the front so bleeding the rears would be difficult. Either support the rear axle with a pair of jack stands to keep it closer to its normal position (make sure it doesn't flip forwards off the lift) or put the truck back down on all fours before bleeding the rears.
x2 on Jon's recommendations to replace all non-OEM with new OEM parts. Brake lines are cheap, lives are not.
:cheers:
Nonsense? For those who don't have tons of money to throw around, as I assume hard line will cost, especially on shipping, used is not a nonsense idea. Especially hard lines, maybe I should have mentioned the rig I would be getting the lines off of has 17,000 miles on it, and they were in great shape no rust. I can understand not using used rubber lines.
I am getting a very bad vibe from this board, it keeps on happening. Its not that I don't appreciate the help, but I could do without the bs attitudes. :cheers:
