Braking issue
IL
i finished rebuilding the knuckles yesterday. New rotors and pads. I took it for a spin yesterday and the abs light came one. This morning the abs light went off but the brakes were acting up. The petal got really stiff and the cruiser did not want to stop. Eventually the petal loosened up a little and the cruiser stopped. The abs light came back on and the braking issue seemed to go away. I'm not sure if abs issue has anything to do with the braking issue. Any ideas?
First thing to check is the preload on the wheel bearings. Remounting things sometimes hangs up and the bearings don't fully seat when torquing the nuts and staking them seems right. That can affect the ABS sensor, which is sensitive to everything being correctly seated in the hub assembly next to it, a possible explanation given you just had it all apart.
If it's worse on one side than the other, that's another sign that one side is off (although both may be, one may be worse).
Another thread here discusses a similar issue that popped up on the trail. I recently had a loose wheel bearing and the first symptom was what felt like a warped rotor, followed by a isolated "death wobble" incident. Eventually came down to a wheel bearing that was loose. Adjusted to specs (there's lots of pad left and the rotor looked good), almost all the wobble in the brake pedal ("death" or otherwise) was gone.
If you have to get back into it that far, be sure the face of the ABS sensor is clean, as grease or other contamination can also cause wonkiness in the ABS.
Thanks. When you say wheel bearing are you referring to the one on the hub? I'll reclean the abs as sensor and hopefully that solves it.
Yep, the ones under the big 54mm nuts that are under the driveplates at the end of the hub. With the tire lifted off the ground, try to rock your wheel top to bottom and left to right. It should stay. If you get movement, the bearings are loose.
Just coincidence, but I was thinking about writing up my checking into unexpected oddness in brake pedal feel, like side to side being different, as a possible indication of wheel bearing issues. In my case, I probably should've disassembled and lubed them some time back...my excuse is I was in grad school, so have been catching up on PM and trouble reports. Thinking back on the origins of this repair caused me to remember the braking issue from a few months back. I wouldn't have connected the two, except my braking issue went away once I got the bearings re-lubed and adjusted without any further ado. [Didn't lube them yet, waiting for time to do both sides. Need to check DS still...make a note of that...:slap:
It's really weird. I was doing 70 mph on the highway. No vibrations at all. When I started the cruiser the abs light was off. My first stop the issue occurred and the abs light came on. The brake issue never happened again. I even drove around the block and it stoppe fine. As far as I can tell it is only happening when the abs light is off. Maybe a concidence but still odd.
If the bearing tests OK now, then most likely a sensor issue. Search might be your best buddy here. When I've had things apart, I treat them like biohazards and try not to let anything touch 'em.
That sounds like ABS thinks it's needed, so is kicking in at what seems to be an inappropriate moment. Something's not right.
Could be...pulled out my trusty FSM.
First, you probably want to read the codes via the procedure in the FSM, which can pinpoint the issue.
It wants to be sure the CDL is off, as this disables ABS in factory config. You probably know which it is for you.
Another piece of lowhanging fruit is the harness for the sensor, plugged in and good.
Here's what it suggests when "ABS operates during normal barking."
Check for codes.
Check check the sensor mounting bolts - tight? etc, etc
"Is there foreign material or ferric chips on the sensor tip?" --> "Clean chips from the speed sensor."
Check for codes.
Thank you!
