Brakes
Orlando, Fl
i've had all my brakes redone, new wheel cylinders, new brake master cylinder, new shoes, pads, and it squeeks, is that normal?
Jonathan/SandRider
What did you do to the drums?
I do not see anything about them listed....
Glazed drums can cause this...
Good luck!
-Steve
Jonathan/SandRider
You said new shoes and pads ... do you have disks up front?
all drum, all around. and i didnt have anything done to the drums them selves. is the squeak normal?
Asbestos (or other) dust on the drums can cause a squeek. How long has it gone on, and is it as you apply the brakes or constant?
its been going on for a week or two, and its normaly just when i apply the brakes, but at times, it just squeeks when im rolling
If you set your brakes correctly, they should be dragging just a hair. They will wear in over time, and as they do so, they'll create brake shoe dust. I don't know, but that may be all you are hearing.
They will squeek pretty bad if the shoes are not arced to fit the drum properly, at least until they wear in. Shops will do this for you if you have the drums turned.
I am a little embarrassed to admit that I am too lazy to always get them turned as long as they are in spec, round, not glazed and have an even surface.
