brakes?
hello i was going to change my brakes in the next coming week or so and was unable to find in the FAQ if the brakes were the same on 1991 hdj81 as the fzj80 ? i can get a good package front and rear rotors but he said it's for a 1993 fzj80? any help or suggestions is greatly appreciated.
I believe that they are the same but don't quote me on it... someone will chime in here soon
if you've got disc brakes in the rear, then they are almost certainly the same as the 93 discs.
If you have drums in the rear, then probably you have the earlier front discs as well (91/92 has smaller rotors)
so go look at the rear to see if they are disc or drum
The brakes are a very picky thing on the 80. There's a lot of things you can get away with going with cheap aftermarket parts, but brakes on the 80 are not necessarily one of them. The brakes aren't that great to begin with and this is one extremely heavy vehicle. I would recommend seriously considering OEM parts or at least the highest quality aftermarket you can find.
I noticed a huge difference in braking feel and performance, when I went from nearly new aftermarket pads that the PO had put on, to factory pads, for example.
wow thanks for the quick replies! i just had a look and disc front and rear. i will ask for a name brand on the pads and the rotors are up-graded cross drilled and slotted. i am pretty new to the lc80 scene so all the help is great and i just got a camera so i can put up pics of my iron pig soon
