Brakes
Just had my front brakes serviced at the dealership. They had lasted 23000 miles but were at 1mm. The job cost $428 which included an oil change. The only thing that sounded fishy was when they said on Landcruisers, they also have to repack the wheels. Looking at my records, they didn't do that last time. What do you think?
PS, I have no skill to do brake jobs.
If they replaced the calipers then the wheel bearings should be inspected and repacked since they come off when the hub assembly is removed.. If just a pad replacement is done, then the bearings aren't removed.
Tom
If that price included new rotors then the price would be on line. As mentioned earlier, if rotors are changed, the wheel bearings would need to be repacked.
Riley
at that price they did not replace the rotors....
That's what I what thinking! I would want to know where that dealer is located! But for them to mention a repack, they must have done something more than just replacing the pads.
Riley
For proper maintenance, the F&R wheel bearings should be repacked at 30k mile intervals; regardless of whether you are replacing the rotors or not. This service is typically done in conjunction with pad replacement.
-B-
Any chance they turned the rotors...eg resurfaced them..in which case a bearing repack is in order.... the front caliper removal doesn't require removal of the bearings
if they only replaced the pads, then no they should not have repacked the wheel bearings, but I also find it hard to believe that is cost $428.00 to replace the pads alone with an oil change:eek:. You really dont need much mechanical skill to do the pads on a cruiser. They are very simple to do compared to many other vehicles on the road. If you can change the tire on your cruiser, you're already a third of the way to figuring out how to change your pads. If it's going to cost this much everytime, I think it would be worth learning how to do.
-B-
Now it makes sense. Thanks B for the info. Most on here just continue into the axle and do the whole birfield job. So just repacking the bearings seemed to be a waste, but very understandable for a dealer.
Riley
