Brakes need bleeding on road
RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
Nahant Ma.
Website
www.youtube.com
wuick question my brakes are almost to the floor I’m in Texas currently. I’m wondering if long range,altitude and temp change can cause the need to bleed. No leaks I can find all send well.
No none of that would affect them. A bad line , leak or bad master or booster, could be issue.
Not so much booster, but loose wheel bearing(s) can also cause long peddle.
maybe your master cylinder is leaking internally.
is your fluid reservoir low?
Caliper bolts work themselves out causing braking failures! This can be catastrophic.
Are you near Houston at all? Let me know, we can help.
Im at Arkansas Oklahoma border grabbed a new master cylinder from cruiser corps
