1992 FJ80, front discs, rear drums.
A couple of months ago I went through the brakes and put new pads and rotors on the front, new shoes, drums, and hardware kits on the back, and new brake booster. Brakes worked like new, even the parking brake. Better than ever since I bought the truck. I never thought an 80 could stop so well.
This morning since I have a day off work, I had some errands to run in town. On the way into town I noticed when I applied the brakes there was a bit of a rubbing noise coming from down around the pedal and I could feel a tight spot when first applying, but brakes still worked great. I guess I need to see what the sound is when I get home, I said to myself.
I stopped by the parts store for oil and a filter and went by the tire shop for a front end alignment since I had just done a "tape measure alignment" when I installed the OME lift.
On the way home I was admiring the improvement in steering and centered steering wheel. As I came up to an intersection and applied the brakes, the pedal is all spongy and it's not wanting to stop. Pumping the brake did not improve it. I shifted to neutral and had enough brakes to stop in time.
I pulled over and the first thing I checked was the pedal linkage. Nothing looks amiss. I then popped the hood and checked the fluid level. Still full, same as it was before. I looked underneath and could not see fluid on any wheel or line.
I did the redneck brake booster check by holding pedal down and shutting off engine. Pedal did not rise. Next I pumped the brakes a few times and started the engine while holding down pedal. Pedal fell just a little. Then I let it run a minute and shut off engine. Pumped brakes and the pedal came up a little each time. The engine is running smooth as silk even at idle and when applying brakes, so I don't think I have a vacuum leak. The booster and check valve seem to be OK.
Brakes are still spongy and not stopping good. I limped it home, making sure to allow plenty of room in front and shifting to neutral each time I had to stop.
Once I got home, I crawled underneath and checked each caliper and drum and the lines. No evidence of a leak anywhere and reservoir is still full.
So My best guess is master cylinder, but I wanted a second, third, or even fourth opinion before I order one.
