Brakes help, diagnostics
Davis, CA
Hi,
I've got a 1992, 202K, stock.
What I've been using for trouble shooting: Troubleshooting Guide for Brakes
Initial problem: Initially the pedal would sink when at a stop light.
What I've done:
1) Replaced master cylinder twice with re-manufactured ones. I bench bled.
2) Thought it just needs a good bleeding. Went to shop to power bleed.
3) Thought it was the axle-to-caliper hose on passenger side because it was twisted. Got it untwisted, checked for bulges while someone stepped on the brakes. Hose looks and feels okay. Same on drivers side.
4) Pulled the front wheels, checked calipers, don't see any leaking fluids. Wheel bearings are a bit loose (1/4 inch of play?), but this would cause a mushy pedal, not no brakes right?
5) No obvious leaks along brake lines.
6) Pulled the rear wheels. No obvious leaks. Changed out the passenger side wheel cylinder. Plan on doing the driver's side tomorrow. For future reference, the two bolts holding some type of black box near the washer fluid works to screw in and get the drums off.
Current Problem: Now I got no brakes, there is very little resistance in the pedal. It won't build up any pressure. I can't get fluid to the rear. Not with 2-man, and not with a MityVac vacuum bleeder.
Hunch: I think it's gotta be something wrong with the rear system. After putting the second master cylinder in, I had a little bit of brakes. Enough to get around town. I tried to bleed the rear passenger wheel, no fluid comes out, then it went to crap.
Thanks a lot.
I'm assuming you are not losing any fluid and your brake pedal goes down slowly with steady pressure but your brakes engage.
I've had that problem. All it took was a master cylinder repair kit. When you replace the pistons, feel the inside of the master cylinder for scratches. If you find some deep one, replace the whole thing.
Kalawang
Kalawang
Yeah, that was the initial problem. I've been through 2 re-manufactured master cylinders, so I'm assuming thats not it.
For now, I'm going to replace the wheel cylinder on the driver's side. Then do a combo 2-man + vacuum bleed to try to get fluid to the rear. I'll try adjusting the LSPV too.
But if this doesn't work, then I'm gonna try a new master cylinder. If that doesn't work, than I guess its on to the brake shop.
Both wheel cylinders now replaced. Still can't get fluid to the rear wheels.
Pulled the line that connects the rear wheels to the LSPV, and it was dry. Applied a vacuum to suck at the LSPV and got just a little bit. So no fluid is getting pass the LSPV to the rear. Tried to reset it by opening the rear bleeder screws and stomping on the pedal really hard. Did it a few times with both the engine on and off. Won't work.
I give up. Been trying to fix it for a while now. Scheduled an appt. to take it to a shop tomorrow. Hit the hazard lights, put it in L, and use the E-brakes. It'll be so cool.
Before I took it in I'd swap the LSPV for a T fitting.
The LSPV may be blocked or (nearly) fully closed. A T fitting will be a couple of bucks, and save you a trip to the shop.
I read about that when I searched. But, not sure I wanna just bypass it. If it is messed up, I'd rather just put a new one in.
Anyways, as of right now, I'm done with it. Non-ABS brakes are relatively easy to understand, and I tried to fix it. It's going to the shop in the morning, let them deal with it. Mechanics gotta eat too right?
The primary purpose of the LSPV is to prevent the rear brakes from overpowering the front brakes in a panic stop situation.
This is useful when comparing apples to apples--drum front to drum rear, or disc front to disk rear. However, with drum brakes it's virtually impossible to overpower disk brakes. Drum brakes simply don't work that well for stopping (now holding, they work great for that).
Removing the LSPV will mean that your drum brakes engage fully, all the time, instead of proportionally. This may mean that you will go through rear brake pads faster than with the LSPV, but it also means that you will stop significantly better.
I've heard nothing but good things about removing the LSPV from folks that have done it (*ONLY* with rear drums). The LSPV can only limit how much braking power you have, and with drums you need pretty much everything you got.
You'll probably need to replace the LSPV if it's plugged anyway. So all your mechanic is going to do is either keep the truck at the shop until he gets a new one (which you'll pay through the nose for) or swap in a T fitting.
Go and spend the $15 (or whatever) and throw a T in there. It won't hurt you any, and can only help.
Before putting in the T however I would check the lines going *INTO* the LSPV and see if there is flow there. If there isn't then you may have a kinked brake line further up.
I tried to check the line going into the LSPV, but can't get it off. I semi-stripped the bolt trying to get it off. So if I got a T-fitting, I can't replace it anyways. But I don't think the LSPV is clogged, it just needs to be reset. Hopefully the mechanic knows how to do this.
The LSPV can't be "reset". If you tried adjusting it, you have to have the original mark that you made (there is no factory setting).
If you stripped the end of the line going into the LSPV you will need to replace that entire line. You should use flare nut wrenches to work on brake lines, not box ends. Ask me how I know....
Get a set of metric flare nut wrenches (Harbor Freight actually has a suprisingly good set), order the new line from Cdan, and replace it yourself. You'll save yourself a ton of money, and learn a lot in the process.
Replacing the lines isn't terribly hard, just time consuming.
I googled and found that brake proportioning valves can get "air locked." And one way to "reset" it is to open the bleed screws and stomp on the brake pedal. This is supposed to equalize pressures and let fluid to the rear wheels.
I thought about adjusting it, but didn't.
I did use a line wrench. Should've sprayed it with something to loosen it first. I was stripping the bolt, so I quit.
There is a bleeder valve on the LSPV to let any air out. You bleed it just like you would any other point.
If you unhooked the lines from the rear of the LSPV and were getting very little fluid it's not air. You have blockage or a kink somewhere in the lines.
If you've stripped it already, then I would simply cut the line going into the LSPV. You're going to have to replace it most likely (unless you get really lucky with some heat maybe). Anyway, cut the line, take out the LSPV and line, replace the line, and replace the LSPV with a T. That's what I'd do myself.
If that seems daunting to you, then take it to the mechanic. It'll be a tedious and messy job.
The actual LSPV bleeds fine. Fluid gets there, and to the fronts. It's the LSPV itself that is not letting fluid to the rear. I know there are two lines that go INTO the LSPV, but as I said, I couldn't undo them to check.
It's going the shop. I'll tell them everything I did, and hopefully can get it fixed quick. I know what needs to be done, I just can't do it.
1) Need to get fluid pass LSPV to the rear.
2) Make sure master cylinder is good.
3) Check all lines and hoses.
4) Possibly adjust booster rod.
Perhaps I missed where you stated you tried this:
Detach the arm from the LSPV on the axle, push it up towards the body and see if you get fluid out of the rear cylinders.
I was gonna do that (adjust LSPV), but didn't after I couldn't get fluid and concluded that it was somehow "air locked." Its dark, but I'll go try it real quick.
EDIT: Just tried it. Detached bracket from axle, pushed it up and kept it up. Pulled rear line, no fluid.
Any update on this?
Yes, the mechanic replaced the hard line from the LSPV to the rear axle and would you believe it if I said put in a third master cylinder? I don't even think the hard line was taking in air initially, it probably started to though after I pulled it to check for fluid. It was the master cylinder all along. Apparently its quite possible to get two defective remans.
Problem could have been solved for $170 and half an hour. But it took me two weeks and $600+.
Lesson learned. Buy NEW (non-reman) master cylinders. Doesn't have to be OEM, just new.
