Isn't that the whole point of the LSPV?
No, that'd be the point of ABS.
The LSPV is designed to prevent the rear brakes from overpowering the front, which would be "a very bad thing" in a panic situation.
I'd be willing to bet that you'd be pretty hard pressed to lock up the rear brakes before the fronts (with drums, obviously the same thing does not apply to disk brakes). Going out to a gravel lot, disabling ABS, and locking them up will show you which locks up first.
Remember that in a panic situation with the LSPV your rear brakes will be
less effective than in normal stopping situations (exactly when you need them the most).
As an example, after I put in my lift I didn't adjust the LSPV right away.
In normal stopping situations I could stop actually pretty well (noticably weaker than stock, but really not bad at all). On my way to home from work one day I had an idiot pull in front of me and slam on their brakes. I slammed on mine (instinctive reaction), expecting to have plenty of time to stop as there was a decent distance between myself and them, and I wasn't going all that fast (30-35 MPH).
Because I hit the brakes hard the weight transferred to the front to a greater extent than normal. This caused the LSPV to essentially cut nearly all braking power to the rear (as rear weight was transferred to the front), and I ended up taking
longer to stop with a hard stop than I did normally.
I would have rear ended the car in front of me had they not pulled forward some at the last minute.
Needless to say that night I adjusted the LSPV.
Anyway, all that to say is that you can be just fine driving normally with the LSPV adjusted the way it is. Until you pull the ABS fuse and test it, you'll have no idea how much longer it takes to reach maximum braking on the rears. With a panic stop your rear brakes should be locking up shortly after your fronts (with ABS disabled of course). If you're travelling 10+ feet between the time when your fronts lock to when your rears lock (depending on speed), then you need to adjust your LSPV further down.
The problem is with the drum brakes is that several people have reported they have their LSPV adjusted all the way, and still don't have enough power to the rear. The only solution at that point is removing the LSPV completely, and putting in a T fitting.
As I said from the start, it'll be extremely difficult (if not impossible) for the rear brakes to overpower the fronts with disc fronts and rear drums. Drums are
not very good for stopping (though they are great for holding). I would personally have no qualms about swapping in a T fitting from the start and calling it good.
