Brakes and Booster
Orange County, CA
I recently purchased a 1968 FJ40, in great shape, so far so good.
The brakes are all stock, and obviously require a LOT of pressure, so I want to add a booster and possibly front disks.
I did the same in our 1969 Chevy Nova pretty easily, so I thought I'd throw it out to the group to see if you have any input I should consider, including doing all 4, and which brands, and any hurdles I should be ready for...
Thanks in advance!
With the 68 you have to get a spacer to clear the rib on the firewall . I Myself have 4 wheel disks with just a Non abs FJ80 master and it stops fine . I had to get the Adapter from JT outfitters to go from the 3 bolt Master to the 4 . I also bought the Spacer that allows a Booster to clear the rib but have not installed a booster to try it yet
Lots of directions you can go here. I have a '67 and have the same firewall rib issue you have. In order for your booster to clear the rib, you need a mount that will extend the booster beyond that point. There are lots of writeups on this and vendors who sell the adapters.
Years ago, I went with a Geo Metro brake booster with a 1-inch bore master. However, I am powering disks on the front and rear. Definitely do lots of reading; there are lots of good options to improve braking.
The best frt disc brake set up is factory Toyota from later 40s or pickups. Swapping either complete frt ends to swapping knuckles and birfields.
Also search knuckle rebuild too. Rears are using a Monte Carlo calipers with the appropriate bracket and GM rotors. Use the search function either thru here or Google and look for mud posts. To start your research go to FAQs at the top of this section and look at Tech links, also scroll down to front ends. The 1st 2 threads are key to sourcing parts. There's also sections for rear ends too. Some of the info is older but basic to the swap. Thru the yrs folks have tweaked things for better performance, so search.
One thing to be aware of is your stock system uses 9mm for the brake line fittings. Newer stuff is 10 mm so plan on making new lines or at least find adapters or adding a 10 mm fitting, (or what ever size the new stuff uses) on the new parts end. As stated above, Toyota parts are the way to go and finding a newer disk brake axle makes it a relatively easy swap.
I'm curious how the vacuum is generated on the early petrol engines - is it just connected directly to the inlet manifold?
How well does this work under repeated braking?
My diesel engine uses a vacuum pump on the alternator and a large vacuum reservoir to enhance performance.
I've updated this to use an electric vacuum pump with a smaller tank, and I'm very happy with the improvement.
