This is a dumb question but I got a strange behavior to report out of my vac booster. I disconnected the hose from the intake manifold and stuck a Blue point suction pump deal on it. It holds vacuum no problem. I operate the brake peddle and the vac slowly goes away with each pump.
Here's where things get weird. I try to create a vac again but no vac is created. I have a leak of some sort, I think but not sure.
On the road, the 80 stops fine, no weirdness. I'm just chasing down all of my vac leaks which become turbo boost leaks while on boost and came to this area of the engine bay. I'm also chasing down P0171 "too lean" condition which can be triggered by pirate air not accounted for by the MAF.
The check valve and the hose at the booster are brand new and came with the turbo install kit.
Ideas?
Ideas?
