Brake Switch?
Hey guys, I'm having some unusual problems with me tail lights. When I got the cruiser, I noticed they didn't work. I Tested both sides at the switch and found that juice was flowing through both. So I followed the one to the tail lights and within a couple inches I found it disconnected. So I plugged it in and now my brake lights comnstantly (makes sense since juice was flowing through both sides with the pedal up) and when I push the pedal down the lights go off. So I remove the switch, clean it, and found out the button was pushed in too far (it popped back out after playing with it). So that was about 2 weeks ago and then one day I noticed after turning off the cruiser that the brake lights were still on. When I set it up, I set the jam nut properly so the brake pedal wouldn't "bottom out" the switch again. But now whats also weird is that the fuse is breaking, but it's more rather melting, or worped (sp) inside the glass tube. I replace the fuse and the same thing happens every time. It never comepltly breaks, just worps. And in the mean time, my tail-light, instrument dash light, and interior light fuse blows. And I mean it blows as soon as the headlights go on. Both fuses are using the appropriate fuse. Never before the brake problem have I blown the instrument panel light fuse.
Sorry for the wordy background. Should I get a new brake switch? When I removed the switch last time, I put "liquid electrical tape" on the bare terminals on top of the switch so it wouldn't short out. Is the shorting out tail lights fuse just a coincidence? What would you're next move be? Thanks for the help.
You have two separate issues. First there is a short in the headlight, tailight, instrument light or interior light circuit. Try to isolate it. For example unplug the headlights then try it, then the taillights. Once you find which section it is then you can try to track down the actual problem.
Second I would replace the brake light switch.
