Brake Problem
Grass Valley CA
Hi all, we have been having some braking issues that I do not like at all. I was hopping that someone might be able to point me in the right direction. The breaking does not feel the same overall, the thing that concerns me the most is that is seems to intermittently (more so when heading down hills either forward or backwards). The pedal fades and takes longer to stop also when it does this I feel loose play in the pedal itself as if something is loose or floppyin there. It is as if it is thumping or kicking back at me as it drops away.
Another thing to note is that a few times the ABS light has come on.
Thanks
Sam
Does it "pump-up" if you hit the pedal a couple times?
Dan not sure what you mean by pump-up. After it does the before mentioned thing while trying to stop going down a hill the brake seems to reset or act fairly normal.
It is like a jerky action that is just not right!
Tree says that it first started last summer after a front axle rebuild and has progressively gotten worse. I first noticed it in Death Valley but I don’t drive it on a regular basis like she dose. I checked for leaks, checked the fluid and the caliper bolts also checked for play in the wheel all was good and still looks good. A few weeks ago the system was drained I put on Slee brake lines (axle to caliper) and put all new fluid in and it did not help. Just seems to be getting worse like I said.
To me it sounds like you have an issue with one of the front ABS sensors, or the wiring harness. I don't know who did your front rebuild, but one of the common errors people who don't know 80s do is pull the axles out until they hit the ABS sensor tip and damage it. If they're really dense, they'll yank until the delicate tip is badly damaged. The other common error is yanking on the wires to pull the sensors out, which is a bad thing on a circuit that's extremely sensitive to damaged wires due to liability. So, I'd clean the area around the sensors fanatically, then pull them out (one single screw) to have a look see. If they're full of metal filings, you may have another issue, but at least you'll know what's going on. Sounds like classic ABS engagement due to sensor issues to me. Classic.
DougM
LOL….This is what I have been suspecting all along now. it’s a long boring story but the first time I broke a cage and needed the truck fixed asap, so I paid a 4x4 shop to replace the birfs with long fields. But as I learned more about the truck I found that he did not replace any seals in there and a few months later I with the help of a friend did a full service job. However I did most of the teardown and I had a 93 book that did not show the ABS sensors. So I had these things in my way that I thought might be ABS sensors but was not totally sure and because there was so much crap caked around it I did not see how to remove them. But before I did anything I called the person at the 4x4 shop that had done the work before. He told me that yes they are sensors and that you can’t get them out . Anyway after tugging and bumping it I decided that that guy is a Fing idiot and I called a NorCal friend and he said yes it’s a sensor and that there is a bolt right next to it holding it in. After a second of chiseling I found it.:mad:
I thought that mabe I had gotten away with this blunder but I guess not.:o
Since that is a expensive fix is there anyway that I can make sure this is the problem before I call Dan.
Yeah, happily it will be a quick diagnosis. Pull both front tires so you can easily sit right there and clean the area around the sensor before pulling them. Seriously clean it, too as in wire brush, then toothbrush and compressed air, then degreaser or shot of brake cleaner so there's no chance that sandy grit will fall in. Then pull the sensor out and I think you'll find it/them crunched. You don't have to remove anything else. Once the wheels are off, 10 minutes of cleaning and they're a single bolt to remove. Someone here may be able to provide a clear shot of what the tip's supposed to look like which you can compare them to.
So the good news is about 30 minutes of work will settle the diagnostics. The bad part's going to be the cost. I believe new sensors must be ordered in pairs with the wiring harness to protect the integrity and operation of the ABS system itself. Dan would be the guy to talk to and ask about options, etc. Since these parts can be stripped off an 80 in about 10 minutes, he may also know of a Mudder in your area that has pissed him off lately, and can provide the exact address of the donor vehicle. Oooh, he's got the powah!!!
DougM
