Brake master issue. Seen it before?
Louisville, KY
Hi all. I have a vehicle, old Ford 3500 (78) that I am trying to bleed. I just cannot get the air out. Here is the strange part ( never have seen it), with the MC cap off and viewed from the cab, when I press the brake pedal and then release, there is so much back pressure that the fluid shoots back out and out of the MC like a geiser at Yellowstone. It will do this WITH the bleed screws open. On any other bleed job, I have only witnessed a draining of the reservoirs in the MC. I am thinking either a severely clogged line or a bad MC.
Thoughts? yeah, I know it is not a cruiser but, I know that hydraulics are hydraulics.
Thanks guys.
Juke
Is it possible there is a lot of junk built up in the bottom of the res? I has something like this happen on a 1968 LC Master. I had the cap off, let off the brake pedal and it burped all over the place. I emptied the res, and removed the master from the firewall. Cleaned out what appeared to be sludge and some oak leaves. Worked pretty well after that.
Could be. Thanks. I am thinking a new MC is coming. I forgot how cheap Ford parts are compared to LC's ( :
55 views and 1 response? Come on fellows, what do you think? Has this not EVER happened to you all?
Thanks.
Ya, clogg makes sense to me. Are the wheel cyls working at all? Have you disconnected and blown through the line. If the wheel cyls aren't actuating, it could be a pinched line.
You said it does it with the bleeders open, does it pump fluid out the bleeder when the pedal is pressed?
I had it happen with a motorcycle once. I had to crack open the brake line at the caliper and bleed the air there. Once the line was bled I could bleed it at the bleeder...Worked fine then. I thought the Master cylinder was air bound and wouldn't let the fluid move past the MC.
Kevin
Did you benchbleed the MC? I'll bet it solves the problem. You may get people that tell you this is unecessary but just ignore them.
I can't give you a scientific explanation of the geyser phenomena but nearly every MC I have ever bled does this same thing whether it was automotive or motorcycle so I have always considered it normal. Just put the cap back on after topping off and it's a non-issue.
Thanks guys.
Gangle: That is odd about the geyser. My experience has been the complete opposite-this includes 3 MC on 40's alone. Calipers do actuate and they stop fine but require a pump or two to build up pressure-I know it is an air issue. I will try a MC bleed.
I don't believe it is air making the geyser as there are no bubbles. I think it's a stream of the fluid.....does it on my Suxuki GXR1000, Honda CR250, KTM 450 EXC and wife's Exploder.
I just installed a minitruck MC from Marlin in an attempt to solve my 4WDB proportioning issues. It squirts up just like by 09/75 FJ40 MC did. I bench bled, installed and had the same problem, acting like I didn't b-bleed it. I just cracked the lines at the MC, made a few pumps, tightened and then bled the calipers as usual. That's all it took to remedy the air problem. Now if I could just figure out the proportioning issues.............
Let me clarify, I think my issue with the brakes, not the MC, is an air issue. On a new OE Toyota MC, with a bleed screw opened say on the front PS disk, I can pump and the only consequence is a very big loss of fluid in the reservoir i.e. no geyser, no back pressure.
Thanks guys.
