Brake Master Cylinder Question
Wyoming
Im not sure what the name is but it is the rubber seal on the plunger - pic below- is it called the Main seal? I can find rebuild kits for the Master Cylinder (for example the Raybestos MK1631) but cant locate where to buy the main seal alone. Its kind of frustrating, since this is easily replaced on the plungers; are they available? Is it just not wise to replace only the seal and not the plunger/spring? Thanks for the help!
OEM MCs are available for not much more than the rebuild kits. After 30 years, you probably need one.
https://www.rockauto.com/en/moreinfo.php?pk=1945130&cc=1276556&jsn=390
But for your question, Toyota just calls it a boot: Part # 47265-20050 looks like it's still available.
But it doesn't look like what you're showing... You need the one on the end of the MC or on the top, where the reservoir feed tube goes?
X2 on what @Spike Strip said above, after 30 years, why bother with a rebuild. Just replace with OEM nothing else.
brakes are 1 or 2 things on my rigs where I don't scrimp and try to save a few dollars.
I do not have a 60 series but do have an 1987 2WD truck that I replaced the brake master on a few years ago.
Just for fun, I decided to take apart my 28 year old (at the time) original Master Cylinder and found major pitting in the bore where the seals contact the bore.
I contemplated rebuilding the original but the pitting lead me to buy a new Aisin master cylinder instead. I would not feel that the new seals would last too long and for such an important system, I figured a new part would be best.
What is the condition of the master cylinder bore on your Land Cruiser?
Also, regular brake fluid changes would go a long way to keep pitting to a minimum. I don't think the brake fluid was ever changed in my truck before I got it.
:cool:
Pitting is very common in old MCs that have never had the fluid changed, that's why the rebuild won't last: it chews up the new seals very quickly and you end up having to replace the MC anyway. Plus, if you don't use the correct 'rubber grease' with the rebuild the seals can deteriorate quickly.
I've successfully rebuilt a couple old, badly pitted LC MCs honing the MC with a 20mm ball-hone, but between the cost of the hone and the rebuild kit and the cost of the Toyota Rubber Grease, it was the same as the cost of a new MC .
Great input folks! Thanks much. Ill just replace the MC; not that much more expensive the doing the rebuild--- but not as satisfying..
