Brake line extensions using stock flex lines?
Folsom, CA
I'm installing a 4" lift on the 40 and am using some stock brake flex lines I picked up at the PMC swap meet to extend the original flex lines. The question is - do I use the cone/flare interface as the seal between the original line and the extension line or do I source some copper disks to seal the cases against one another like is done on the flex line connection to the "T" on the axle? At this point I went with the former approach, but it required that I remove about .050" off the end of the female fitting on the "extension" line to ensure that internal cone and flare would seat. This connection leaked the first time I tested it so I snugged it up a bit and it seems to be holding - for now.
Thanks,
A similar topic was covered a little while ago in this post.
https://forum.ih8mud.com/showthread.php?t=79754
I don't know the answer to the question, but if I had to choose between the two choices, i'd go for the copper washer, just because you'll never know for sure if the cone/flare is really seated properly, at least you can see the washer interface. Just the fact that you had to modify the fittings to make them work seems to tell me that they weren't meant to go together in the first place. It might work for a while, but do you really want to take that chance?
Hey, I know where you got those! :cool:
When I got the new ones, only two out of four came with the copper washers, only on one end, and none of the ones I took off used them, so I didn't use them either. My stuff is all stock, but if it helps I don't have any leaks in my lines without the washers.
If there is an inverted female flare in one hose and a male flare on the other, screw them together....
Or just purchase a longer, one-piece line and be done with it.
:beer:
Thanks for the link - not sure why I didn't find that when I was searching, but I never seem to choose the right keywords. It didn't answer my flare or copper gasket question, but provide a significant amount of good info nonetheless.
I don't have any concerns about adding another joint - it actually provides a very nice place to connect a spring to keep the line out of harms way when the suspension is compressed. I suspect that the OEM brake lines are at least as good, if not better, than the aftermarket extension lines I looked at. If I could find OEM rubber lines the correct length - I would go that route. Anyone have any part numbers?
Cheers,
Thanks - they are working out nicely. I found some copper washers at Napa, so I can go that way if needed. I think I will probably carry them with me in any case. The flare joint seems like the correct way to go to me, but Toyota used the other style on the axle T, so there must be some reasoning behind it??
Cheers,
