Brake lights possessed & intermittent starter problems
Thanks for reading, Newbie here, first post ! Purchased a '97 LX450 a couple weeks ago and need help already!
A few nights ago my wife is checking in on the kids, and then yells out "I think someone is stealing your car!!" I jump out of bed, look outside and see the brake lights are on. I run outside and the crusier is empty. Press on the remote a couple times and the lights go off.
This has happened 2 more times since then. Seems to always happen around 3-4 am (not every nite, unless they are turning off by themselves and I don't know). The last time, the remote didn't turn the brake lights off, pressing on the brake did. Any ideas?:confused:
--Also, could the brake lights being on for a few hours drain the battery that is 4 months old? Since the weirdness with the brake lights, I've had problems starting. Turn the key and nothing but the dash lights(no sounds, clicks, etc). Try a few more times and then it turns like there was never a problem. Thanks
How many miles on the cruiser? Do a search on 'starter contacts' and you should find the answer for your starter problems. Not sure on the brake lights. Are they coming on by themselves or not going off after you park it?
Tom
99k miles. I do plan to work on the starter contacts. The brake lights are coming on by themselves in the middle of the night which is just strange.
I had a similar problem. Mine would just came on even in the highway, mine is the same model. I took out one of the rear brake light, the center light would turn off. So one of the rear light bulb was out just to shut the center brake light off.
what is the starter contact has anything to do with it
