- Joined
- Apr 21, 2005
- Threads
- 116
- Messages
- 26,221
Mark I believe when he said the rear signal worked I assume he meant the turn signals. If that is the case don't think there is a issue with tail light loom.
Missed this thread...
If you still don't have this working, then do the following.
Open the hood. On the passenger side firewall there are two 4 pin plugs. These are the plugs for the rear chassis harness. Unplug the two plugs. Now look at the male plugs only as they are the ones that go back to the rear lights. One of the plugs will have both a Green/Yellow and a Green/Orange wire in it. Use a jumper wire to the + terminal of the battery and touch it to the Green/Orange and Green/Yellow wires one at a time. GO is left and GY is right. If they light up, the rear harness, lights, and the ground for the lights, are all good and the problem must be the turn switch or the Hazard switch.
