brake issues
Weatherford, OK
Lately I've been wanting to add some goodies to my rig like bigger lift, bigger tires, spare tire/cooler/gas can/jack carrier, twin stick, rear seat, electronic ignition, etc. on and on, you get the idea. But as is usually the case, "bugs" need exterminated preventing me from spending money on fun stuff. One such bug is in the brakes. I recently replaced the master cylinder and now although they are very effective and stop quite well, I have to pump the pedal 3 times to get there. This happens every time i use the brakes unless I'm on a street with stop signs every block. Is this a bleeding or booster issue or did I get a faulty master cylinder or is it something else altogether?
You just need to adjust your wheel cylinders. When they are not adjusted properly they have to extend further to contact the drum than one pump of the pedal can push them. 8 wheel cylinders require a lot of volume to move very far.
Look in your service manual or on the tech page for how-to's. A search would probably turn up some info as well.
I put new shoes on the front when i replaced the master cylinder and thought I had them adjusted out far enough, but I will double check and give it a try. Thanks!
ditto on adjust your brakes - and right away! The drum brakes on pre-76 FJ40's are high maintenance; driving with them improperly adjusted is very dangerous.
Assuming you have no wheel cylinders leaking and the air is bled properly.
Some of the older drum brake vehicle can be adjusted by driving them. As long as the slack adjusters are free, put the vehicle in reverse and while rolling backwards just stomp on the brakes. You may have to do this several times. The slack adjustors should take up the slack.
please do not give technical advice if you do not know what you are talking about - especially regarding safety issues like brakes. FJ40's of that era (and possibly of any era) did not have self adjusting drum brakes.
the ONLY way to adjust them is manually with a screwdiver or similar tool thru the adjusting port in the brake backing plates - each cylinder is adjusted indivdually - 2 cylinders/wheel.
