Brake issue
Eastham, Cape Cod
Ok, so a buddy of mine is having a problem with his 40's brakes. Hes got ALL the breaking in the rear, but none in the front. Hes got disk fronts, and drum rears. The lines are hooked up to the right ports, hes using a V6 minitruck rebuilt/new MC and hes got a good booster. Bled the system a couple times. The peddle has good feel, but driving it around the yard the fronts arent hooking up at all. Does this sound like a bad MC to anybody else?
I am just trying to get this guy out on the trail next weekend!
Hey rabid :flipoff2:
has he got a proportioning valve fitted?
are the calipers seized?
lock off the rear brake line and see what happens then...
a std 40 booster is too small IMHO to run disks - upgrade to something bigger - a 60 series worked well for me...
Its a 94 4runner, v6 booster also (hes also tried a few of them to double check that the boosters not bad) from the same truck that was working when pulled.
He dosnt have a Perp valve, wouldnt that just bring the ammount of fluid thats going to the breaks down even more? Another question that was raised was vaccume. The requirements of booster is more than the carb'ed engine can require?
The rear brakes are brand new, the fronts are recent. Is there a random chance that its pushing too much fluid to the rear and not leaving enough for the front? I am seriously:confused: on this one.
