Brake helps..... Please!!!
Simple question. I've got fzj80 axles with 15" rims. I need a caliper for the front. Did someone swap fj80 calipers and rotors onto my fzj80 axles. I ordered a fzj80 caliper and there's no way it's gonna work. I suspect fj80 and fzj80 brake calipers use the same mounts on the axle. Just a smaller caliper and rotor for the fj.
Passenger side works fine and doesn't appear to be ground down to make fit.
I know some came with 15's and some with 16's. Must have been different size brakes at some point.
There was different brakes, 91-92 fj80 had smaller brakes came with a 15" wheel. 93-97 fzj80 had bigger brakes and 16" wheels. *my fzj80 axles have 15" wheels on them. Best guess is that the fzj80 rear disk brakes are compatible with 15" wheels and my front axle has fj80 rotors and calipers on it to accommodate running 15" rims. I ordered a caliper for 91 fj80 it'll be here in the morning and hopefully solve this issue! Next on the list is to re-wire the factory lockers;)
