Brake Fluid
any good brake fluid from an auto store
i use valvoline synthetic that is compatible w/ normal brake fluid- from any auto parts store and prob cheaper than toyota
I think Toyota is DOT3 so look for that or higher
I hope that the longer Slee brake line goes up front cause thats the way I put it. No ABS and Rear drums on my 94. Can someone give me a little bit of confidence I did this right cause that front line has alot of slack.
If you're asking about the SS 3-line kit, acording to Slee website instructions: "On ’93-’97 vehicles there are two front and one rear line." so I think that the longer single would go in the rear.
http://www.sleeoffroad.com/installation/slee_lift_kit_80_series.pdf
HTH
I'm a 94 with a 2 line kit, like the 91-92
I guess then, the best guess is to compare original line lengths and follow that pattern. Unless you can search MUD threads for a better answer or call slee tech line: (303) 278 8287 or toll free: 1(888) 4X4 SLEE.
If compared to original line lengths, it was done correctly. Didn't wanna call SLEE.
