brake fluid loss
Plano texas
Hi, When my master cylinders go bad on the 60s and 62s,they bleed inside or outside the fire wall.Has anyone had one go bad that bled directly into the booster? I see no other leaks. Mike
How do you know you're losing fluid? As the pads wear, the fluid level will go down.
-Spike
Filled the master twice today. The pedal at a long light will sink slowly toward the floor.Feels like the master to me. Mike
I guess you are. :D I have heard of fluid going into the booster on other cars, I'd assume it can on the LC as well. There are only so many places to check, and with that much fluid disappearing a leak at a line or wheel cylinder should be pretty easy to spot.
-Spike
Howdy! Usually, if the rear seal of the master is leaking, it will be wet on the front of the booster. If, not, you could double check by just loosening the mounting bolts of the master and pull if forward a bit. I have never seen Power Brakes leak on the inside of the firewall. It would have to go clear thru the booster. Now, on older ones, w/o power, yeah, just like a clutch master, it can leak inside. John
Thats whats strange with the amount of fluid its leaking I should see fluid somewhere.On the 40s and 60s Its almost always between the master and booster. Mike
