Brake Booster
My brake booster seems to be going bad as the wife told me the other day that she had a hard time doing a fast stop. She said if she needed to stop quick (ie avoiding rear ending somebody) she couldn't do it. After test driving I confirmed her observation. Sooo I went shopping for a new Brake booster. I know the attitude about OEM parts on this board and I second them but I was kind of suprised to see the price difference between the NAPA remanufactured ($284) vs the Toyota ($532). I'm leaning toward the remanufactured. I talked with a local recommended LC mechanic and he said he didn't have any issues using a remanufactured booster since the design is so simple. Anyone have any opinions?
Also how difficult is the booster to get out? It looks somewhat simple but I ran across a thread on this board where someone had to take the intake manifold off to get the brake booster off. It looks like there should be plenty of room to pull it. I've worked on brakes before just never had to fuss with a booster.
I just used a bunch of NAPA remans on my truck. I then had a total failure and my first thought was those same parts. It turned out to be a complete coincidence and the NAPA stuff works very well and saved me some cash.
Every time I've look at a vehicle with a failed boosted it was where the pedal was rock hard and you couldn't apply the brakes at all. That's not to say you don't have a booster problem but it would seem like something else to me. Have you pulled the calipers and inspected the pads?
I took it to a local mechanic that said the booster was bad, but he didn't elaborate on how he determined that. I suspected the booster from info I got here. I did the suggested tests in the Haynes manual and all checked out. The symptoms are: brakes grab good initially, slow down under normal circumstances, but if more stopping power is needed they feel hard as a rock and won't engage any more. I can see this effect even in the driveway if I hit the brakes hard.
The PO replaced the front rotors and pads and right after I bought it I had the brakes checked (they said they were ok) and radiator flushed.
Funny you say
"Every time I've look at a vehicle with a failed boosted it was where the pedal was rock hard and you couldn't apply the brakes at all. That's not to say you don't have a booster problem but it would seem like something else to me. Have you pulled the calipers and inspected the pads?"
I was talking to a local mechanic that is supposedly familiar with LC's and he said the same thing. I suppose I could take it to him on the off chance that he could find something else wrong with it.
Same problem...
Cutter,Running into the same issue as you only i haven't taken it in yet. Everything was working fine and then i get in Sunday night and pedal is stiff as hell when depressed. Looking for anything else I should check. Did the FSM "air tight" check while on my lunch hour today and it passed based on what the manual said. I moved it in the driveway and you can hear the rears engaging on the rotor but it doesn't feel like the fronts are grabbing... Looking for other areas to check before dropping the coins on a new booster.Thanks!TC
