Brake booster
FL
Ok guys. When I got my 40 in December the brakes were downright scary. Replaced the hydraulic fluid with new and replaced front brake pads. At this time the brake booster held pressure. I took the check valve out. It seemed to be working because it would only let air pass in one direction.
They have been much better but I can tell that they aren’t 100%. Just finished desmog. The brakes still work however when parked at idle with foot on brake pedal I can hear a leak from the area where the booster sits. It also drops the idle RPMs. Foot off brake, leak goes away and idle RPMs return to normal. Is it time to replace the brake booster?
I don’t know if this helps but the vacuum leak when the brake pedal is applied sounds loudest On the cab side of the firewall under dash
Air is being sucked into the motor via the failed diaphragm of the booster. The air SOURCE is through the boot and filter behind the pedal...in the cab.
What year?
So replace boot and filter?
Thank you Elder Statesman for your input. I spoke with you on the phone years ago about replacing a carb on a 79. Your council served me well
That’s where I was headed if need be. Is it an easy install ?
The City Racer booster was not as deep as my stock (12/79) booster. I replaced my master cylinder with a different one at the same time, so I ended up cutting and re-bending both brake lines, but if you are just replacing the booster you may well be able to just bend the existing lines to fit. Other than that, it was all bolt-on. Pay close attention to the City Racer instructions on how to get the old booster off. Also, you will want a tool to measure and adjust the gap between the booster pushrod and the master cylinder. I bought this one and it worked well:
Amazon product ASIN B079QGXY55
I think I should do the master cylinder at the same time.
Thoughts?
Not a bad idea IMO; when the master cylinder eventually fails, it will leak out the back into the booster and the brake fluid will corrode and eventually eat up the interior of the booster if you don't catch it right away.
The other consideration is whether you will ever convert your rear axle to disc brakes. If so, then it would be a good idea to use the FZJ80 non-ABS master cylinder, that is made for 4-wheel disc brakes. I used this one on mine (Mud advice) and I'm very happy with it - much better with my discs than the stock master; no more rear wheels locking up first even with a proportioning valve. In combination with the City Racer booster, my disc brakes are 100% more effective and confidence inspiring than previously.
Thank you for that advice. PO had discs installed on the back. And yes I can get them to lock up. Looking at the rust it has to be the original master.
Cruiser Outfitters carry the non-ABS FZJ80 master if you decide to go that route. The brake lines come out the side of that master; my stock master had the lines coming out the top. If your stock master is that same style, you will be cutting, bending, and flaring the brake lines. Not rocket science but you need the tools to do it. LMK if you need more info and a link to a good flaring tool that will not break the bank.
