Brake Booster Right Angle Fitting
Oakley
I'm using a '97 mini-truck booster and in order to allow my carb to fit, I need a right angle vacuum fitting to replace what is pictuted. Does anyone have a source for a right angle fitting or ideas? Pretty short piece to bend safely. Is the fitting barbed and should it just pull out?
If you havnt already ordered one I have a 90* check valve off my oem 76 booster that I just tossed
Do you know if your '76 valve's end that fits in the booster is 3/4"? If so, let me know and we can work something out.
Spray a little grease/lubricant at the joint between grommet and fitting, wiggle out. Correct fitting a new grommet below:
44730-22090 - 90* fitting
90480-24439 - grommet
Thanks for the help with the part numbers and getting the fitting out. Worked great!
