Just did a rear axle job and went to bleed the brakes. I can't get any fluid to come out of the rear calipers. I've poked around and the only thing I can think of is rusted/plugged up bleeder screws. I'm going to go get some new ones tomorrow, but in the meantime I wanted to check if anyone had any ideas of any other issues that might be causing this.
I'm using a vacuum pump to bleed the system and what makes me think its a plugged screw is that when I loosen the screw, the pressure in the line does not drop at all. I also installed the slee brake lines(just the calipers ones so far) so I could have put those in wrong somehow, but i don't think so. I can get fluid out of the LSVP and the front calipers. Could other brake lines have collapsed in the rear?
